One of my zones is set up with eleven emitters that are 0.5 GPH. The wireless flow meter won’t calibrate for such a low flow so I’m wondering if it’s possible to manually set a max flow for a zone like this that won’t calibrate. If it was possible, I’d like to set a limit of 1 GPM. Practically any type of pipe/valve breakage would surpass this limit, then the zone would be shut off and eliminate unnecessary wasted water as a result of the breakage.
@jaylude22 We are currently researching a feature that would allow you to manually set a baseline for low flow zones. Would you like to be involved?
If you are interested, please DM the email address of your user.
