Manual zones on now app
On the new app I do not see how to run manual zones easily. I see I can run one at a time, with quick run but if I try and set up a second one it stops the first. The only options I see in the quick run is run now or cancel. Many times I plant in the spring or fall in multiple zones and need to manually run these zones.
@Bschatzow
Have you tried adding a custom run? It is the upper left hand corner option. This will allow you to add multiple zones to a quick run. Hope this helps.
On what tab? I don’t see this option on my Android app or my PC version. None of my pages look like yours. How do I get what you show?
If you tap the quick run button in the lower right section you will be able to access that screen.
Thanks. See it now.
