Manual operation
For those times that I need to manually control the valves on my Rachio, can I select to run multiple zones? Example: I want to run zone 2, 4, 5, 6, 7, 8, 9 however skip zone 1 and 3.
Yeah, I just recently realized I could do this. When you pull up the manual control just lick on the button that says All Zone and select the first zone you want to run. Set the time, then open up the menu again and select the next zone you want to run. After you are done just hit start.
