I just installed the rachio a few days ago and the experience has been not great. When it rains the watering has not been skipped even when it says 100% chance of rain. I have wi on but still continues to do so
Do you have a fixed, water as needEd or flex schedule?
Water as needed
Looking at your weather station it appears that you got less than .25 inches of rain. If your threshold for rain is set for .25 inches or more that could be the problem. You could lower the threshold.
I have it set to lowest setting 1/18
I think the reliability of this station is poor. Hereās a chart of local stations so you can see the differences. Try a different station that is more reliable.
So if I switch it too c3353 . it shouldnāt water tomorrow morning? Correct
That appears to be the case. I checked 3353 and it has a good record of recording the rainfall. Let us know how it works out.
how do you get so many weather stations? I have one option and its 8 miles away by the nearest airport? It would be nice to get something closer.
After you select Change Weather Station turn on Personal Weather Stations. The Google map should show PWS locations. Your PWS location codes will start with the letters āKMNā. There is a PWS at KMNCOONR26 that may work.
I was wondering why I didnāt see all the personal weather stations around me when I looked to change the weather station on the Rachio app. Apparently Rachio uses Aeris Weather Service and PWSweather.com and not everyone around me with a PWS sends data to Aeris. If they do, Aeris may not use it because it isnāt accurate or consistently available. So my list above is not from Aeris but WeatherUnderground and most of these are not on Aeris. Look at the pwsweather.com web site and see what you can find around you. I was lucky enough to find a PWS a half mile from me. Good luck.
Yea have to buy one.
Another point, if the only PWS you can find is one with temperatures and not rainfall, think about installing a rain sensor. I havenāt used it but a friend of mine uses the Hydreon RG-11 sensor and raves about it.
Thank you. I didnāt realize the pws was an option. Am I correct in that the rachio will poll the selected station one hour before any watering schedule and then make adjustments accordingly?
The way my Rachio has been working is 1 hour (give or take a few minutes) before a schedule is set to run it determines whether to run or not based on rainfall data from my selected weather station. If rainfall over .25 in. has occurred in the last 24 hrs. or predicted in the next 24 hrs., the schedule will be skipped. The app will tell you one way or the other what is happening.
This will help explain the process behind it (Iām hoping next year we are able to notify well in advance of 1 hourā¦)
If Iām using someoneās pws, how does it predict precipitation in the next 24 hrs? Itās not like the owner of the pws is āforcastingā the weather.
The forecast comes from the NWS through Aeris. Even though I get my current or historic data from the PWS, the forecast comes from NWS through Aeris.
I think I found my answer in the link you provided. Thanks
āIf you have selected a personal weather station that doesnāt predict weather then we will pull those predictions from the nearest national weather station to your Iro.ā
