I installed the wireless flow meter a week ago, and it is connected and calibrated. I don’t see any reports in the app on what it is measuring each day, just the usual notoficationsfor how many minutes each zone was on. What am I missing? Thanks for any guidance on how to take advantage of the flow meter. Paul
@Parachi Once the Wireless Flow Meter is installed, paired and calibrated, you are now protected from High-Flow leaks and low flow problems. This week we will also be releasing in-active flow checks which look for stuck valves after your schedule or manual run.
If you scroll down on the Home or Zones screen, you will start to see actual usage instead of estimated. You can click into the Home screen view and see additional information around zone and day to day usage.
