I have been trying to change the square footage of my zones. When I enter the number and tap on the circled check mark, a box pops up that says the value must be greater than zero and less than 10,000. I tap on OK and the numeric keyboard pops up again. Endless cycle.
Attached is a sample screenshot. 500 sq ft surely meets that requirement. There is no other option to Save.
I’m running iOS 9.3.2 and Rachio app 2.6.1 downloaded yesterday. My unit is the 8 zone Gen 2.
Don’t click on the circled I or the circled check mark. Just type your number into the area then click on the back arrow at the top of the screen and it will work. @franz, if you click on info circle, you get this message.
After you change the number, you click on the back arrow on that screen. It will go back to the screen labeled Zone Details. Click on SAVE in the upper right hand corner on that screen.
How exactly are you measuring the sq. footage of each of your zones? I’ve kept mine as default, but that’s not very scientific. Also, it results in false water consumption calculation.
