Hunter Rain Click - white wire to 24V?
I am new and sorry about posting a new thread if not needed.
I read several threads about sensors and in particular the Hunter Rain Click wireless.
I see it is recommended to attach the white wire and one of the yellows to the 24V power.
There is a Common terminal there next to the sensor wiring. I figured that would be where the white goes as it typically does on other controllers.
Reviewing Hunter’s instructions, I do not see one instance where the white wire is powered or connected to power.
@ToddH - the confusion comes from mixing Hunter connections with Rachio instructions. The equivalent in Rachio to one side of the twin Hunter SEN connections is the VAC 24- terminal.
See ->
so that link no longer works…any help?
@ttueric - Here you go:
