Hunter pgp ultra rotors -- time is wacky
Isn’t a catch cup test easier and less expensive ?
Who designed the system? Do you know the well’s production in gallons per minute? What is the static water pressure? Once you know this, then you can proceed with hydraulic calculations (pressure loss) and what the pressure will be at the critical head. Then you know what your head spacing should be. Start from the beginning and work back. Also I do not know how Rachio works with a pump start relay versus conventional controllers. The best pump start relay is a Hunter PSR22. I would be interested in learning experiences with pump start relays and Rachio.
I like those greens but as stated I have no idea if the well can take it. I assume it has a reservoir…how big is it and how fast does it charge?
