I added a zone of lawn with the same settings as other lawn areas, except fixed nozzles instead of rotor and different footage. The new zone will only water one minute shown in the logs. Other zones water 8 or 9 minutes. Available Water on the troubled zone is .07 whatever that means. .12 on the others. What am I missing?
Hmm I have a simple fixed schedule. I went in and manually added time to the duration for the zone. I thought the rachio figures the durations for each zone?
The controller determines each setting value and duration based on your input.
Read this: https://support.rachio.com/hc/en-us/articles/115010542148-What-are-Advanced-Zone-Settings-
Then, dig into your settings and compare the differences.
Thanks, some good info there and the last paragraph basically said for fixed schedules I have to program the run times.
