Pretty simple and straight forward for you…
You have a sensor of some kind that will go to the sensor ports on the Rachio. Looks like you have 5 zones, which will go in their respective zones slots on the Rachio. Lastly, you have a white common wire (the wire on the bottom right) that goes into one of the “C” ports on the Rachio. Set up the zones in the app and you are set!
