I have front yard and back yard zones and valves - the back yard valves all turn on with Rachio, the front yard valves do not…Rachio says it’s running a zone in the front but no water is turned on.
@toby39 - it is probably wiring if half of the valves are working and half aren’t. Is the back yard closest to the Rachio? If you have access to a volt/ohm meter then I’d measure resistivity for the front yard lines individually to the common wire.
I would go to the valve box in the ground and manually turn on the valves for those front zones. If that makes the heads pop up, then I would check the wiring on your Rachio to make sure there isn’t a rain sensor or common wire causing some issues.
yeah, it was wiring - come to find out our gardener just unhooked the wiring because one zone was soaked and we weren’t home for him to tell us…so he just un-wired all the front zones…ugh.
