Freeze pipe pump
It’s a pain to winterize my river pump. Amy way to have a feature to use a spare zone to power a pipe heater? And then use a if temp <34 power on?
I think you could probably set up an IFTTT statement for a zone to run when you get below a certain temperature, I just don’t know if your controller supplies enough power for a pipe heater? The wire terminals are able to supply 24 VAC.
