So for someone coming from a dumb controller to install this next week, would you recommended using a flex scheduling approach or (so I don’t know what I’m missing) move to as needed?
@obmd1, we believe As Needed schedules are easier to setup and configure for someone coming from a dumb timer
I’d personally recommend starting with As Needed first before exploring Flex. Flex is great if you know all of the inputs; root zone depth, nozzle application and/or zone precipitation rates, etc.
For more information on As Needed schedules, please see this support article.
Are you saying As Needed does not factor in settings such as root depth, nozzle type, etc.?
@jemanner, it does for the initial schedule creation, but you can edit zone durations by the minute after, so it’s easier to correct and fine tune for users with input errors who don’t wish to enter the correct data.
Oh, then if as expected with new sod, I anticipate increasing my root depth, it will not reflect in the schedule unless I create a new schedule, i.e. As Needed does not dynamically adjust with changes? Flex does?
Being new to the product and the community, I just want to say that I clearly made a good choice by updating my controller to your product! You guys clearly care about your customers and improving your product based on feedback and Beta results. If only more companies would use that business model…
Thanks guys!
I know you feel that this a step backward for the company, but I truly believe this was a very good decision. I don’t get the angst over Flex being too difficult to use; it was the easiest thing in the world to get started with, and could be improved by adding data or tweaking usage amounts over time for those of us gung ho about getting the most out of your algorithms…
Like I pointed out in another post, you really should be looking at how to enhance flex, not create a fixed schedule with skips (i.e., As Needed), as that approach as implemented is fatally flawed (as the workarounds being discussed in other posts are making clear).
Thanks for listening.
@jemanner, As Needed schedules will dynamically update schedules after zone attribute changes are made
Does this mean you will not be retiring the Flex schedules in Nov of '16? I really like them and hope they stick around.
We will not disappoint our community, especially early adopters
Product team is listening/learning and we will continue to refine the scheduling models.
I also thank you for listening. I understood the concept of fixed (i.e. fully manual) and Flex (i.e. fully automatic). I had issues dialing in Flex, so it was not perfect for me either, but at least I partially understood it.
I still cannot figure out the hybrid “Water as needed” and what it is really trying to do and how it does it. It seems it’s not either manual or automatic, and therefore somewhere in no man’s land
It has been really hot here for the last several days and is now cooling off significantly for the weekend. Waking up in the morning and seeing the magic of my flex schedules keeping everything watered just right makes me really happy to have your product. Flex is so impressive I bought the gen 2 unit and was able to sell my gen 1 to a coworker.
I was planning on trying the as needed setup but these last few days have really solidified my belief that flex is the best setup for my lawn. Thank you for continuing to support them with the new web app.
Chad
@franz - Just seeing this thread and am curious, if I were to purchase a Rachio, would I be able to setup flex schedules as a new customer? If you recall from the announcement thread, I was holding off purchasing because of the loss of flex.
Thanks!
Yes, you can use this workaround for now to add flex schedules to your controller. After that, you can use the apps as normal…
Please know the product team is listening, aggregating feedback, and determining what our next software releases include.
This thread sums up my thoughts.
Thanks for your patience.
@franz - Very excited to hear this! I’ll talk to the wife and see if ordering one might be in the cards for this year.
Thank you very much for re-enabling the schedule. You may be right that this schedule type is over compilated for normal folks but for me it works perfectly so far after fine grain tuning and adjusting. Seeing that it’s gone from my app and web UI was quite a bit of shock at first. I was glad to discover a “back door” to get to the functionality. Why not to keep it for advanced users and hide for normal users? Just make it optional and continue to improve meanwhile to make it easier to use.
Thanks for the feedback, very much appreciated.
We are continuing to iterate and I believe we will deliver the right solution.
Just FYI, I had been doing research over several months while I installed my irrigation system and had decided to postpone controller purchase after reading about Flex schedules being discontinued. I was prepared to continue researching for other controllers when I thankfully saw this update today! Based on your handling of this situation, as of this afternoon, I’m now a customer.
@vnephologist Great to hear, this might provide even more context on flex scheduling.
http://community.rachio.com/t/flex-schedules-community-future/3828/2
