I would like to know if it is possible for me to create a Fire Emergency setting to immediately start watering zones in either two zones at a time or quickly go through zones for two minutes per zone? just playing with this but my sprinkler system was originally set up for wildfire hazard and I would rather have the option and not need it than need it and not have it.
I would create a schedule with the fire emergency zones, setting each zone duration to something like 30 minutes(?). Then add a manual cycle/soak with duration of one minute and soak of one minute.
Disable the schedule and then you can run manually from the remote if you want to start it immediately. It will run each zone for one minute, cycling through the zones for the total duration chosen for the combined zones. Hope this helps.
