Wondering if there is a way to edit the data about what has run and for how long, after a schedule has run. I’d made an adjustment to my system and unknowingly cut a wire that sent the signal from the Rachio to my zones. So the Rachio thinks it ran the schedule but it didn’t. I fixed the wire and re-ran the schedule. Now my historical data shows two runs of the schedule on the same day, and you can then conclude the amount of water and everything is off. Can I edit that false run out?
@petercw2 If this is for a flex daily, from the moisture graph you can empty/fill individual zones.
There is currently no way to remove individual events.
Hope this helps.
