Disable flow meter for winter?
Gen 3 is in standby for winter. Keep getting low flow alerts. Do I disable unit since it will be indoors for winter?
@Bytored Are you receiving low flow alerts or in-active flow alerts? Are you schedules still running?
Low flow alerts. Zero water in line. I am taking out unit tonight.
As said before gen3 is in standby for a couple weeks now and I’ve I just disabled all zones this morning.
Thanks
@Bytored I’m going to have the support team look into your issue. You should be receiving no low flow alerts unless a quick run or scheduled run is happening.
