Controlling 110v appliance using 24v relay
I am trying to provide control for a fountain using the Rachio controller for a client. The only solution I have thought of is installing a pump start relay, hard wiring the fountain pump to the relay, and then running sprinkler wire to a dedicated zone on the controller. Does anyone know of any 24v relay switches that have a built in outlet? This would eliminate the need to hard wire the pump to the relay.
@landstetics - why is there a desire to control the fountain with the Rachio? It may not be important, but this will throw off the water used for that customer - so I’d be sure to set the area and precipitation rate for that zone to be as small as possible.
Why not use one of the intelligent plug solutions, mounted in a weatherproof enclosure if necessary?
No, but it would be pretty easy to mount a box with receptacle and in use outlet cover to the bottom, or drill a hole and mount to the side of a relay.
Tons of relays on ebay but they don’t seem to indicate the coil load. Hopefully they are in miliamps so the controller can handle it. I two would likely use a smart outlet. If the client already has dlink cameras, you could use a dlink outlet and it would control from the same family of apps. You’ll want an auto fill valve on the fountain or a rachio zone that fills it.
Agreed…Several good wifi plugs that work with HomeKit, Wink, Nest, etc. that would work better.
I have done just what you are trying to do. I fill my fountain everyday on a dedicated water valve.My rachio controller waters my fountain for 1 minute every day. The power for the pump is on a separate timer.
Greg
