Can someone explain why when I change duration of watering in a schedule Flex Daily does not reflect this change? It still repost the same moisture levels as before the change. Here’s an example:
100% set:
Irrigation +0.67:
50% set:
Well, the same moisture levels, the same schedule, the same “predicted” irrigation +0.67:
Am I not getting something here? Or the duration is only used for “fine tuning” of the irrigation amount and does not affect the flex schedule by any means? Thanks!
