Can somebody explain how to use Catch Cup data with iro
Hi,
I understand placing catch cups and recording measurements. I even get how to interpret the calculations produced by the Orbit watering schedule site.
However, entering that data into the iro is confusing.
The only thing I came up with is to create a custom nozzle with the observed flow rate (GPM) and putting in the zone size.
Any better suggestions?
http://www.sprinklerwarehouse.com/DIY-Calculating-Precipitation-Rate-s/7942.htm
Follow that formula and make a custom head with that pr.
@RVRoadie. Assuming that you used the Orbit cups and their calculator, you can use the precipitation rate from their calculator and then, yes, plug it into a custom nozzle. Just make sure that you enter the value for in/hr. You mentioned GPM in your posting so I wanted to be sure.
You are right. I get the PR(in/hr) from the Orbit calculator, and also the Distribution Uniformity. I create a custom nozzle with the PR rate, and use the Distribution Uniformity to set the Efficiency %. I fix up the area to match the size of the station, and leave everything else alone.
@RVRoadie That sounds about right! What were highs & lows of your catch cup data, and the total PR & efficiency ? Just curious.
Cup Volumes: 50, 22, 18, 25, 32, 25, 24, 15, 18, 15, 16. This was for 10 minutes. I probably should have done 20.
Distribution Uniformity 63%
PR 0.53 in/hr
@RVRoadie. That looks similar to mine. Thanks for sharing the info.
@azdavidr @RVRoadie Late to the party, I don’t know if you saw this calculator.
Really easy to determine PR in/hr.
Thanks @franz. FYI a couple of us determined a while back that the hydrorain and orbit calculators are identical. Catch Cups. @RVRoadie ended up getting to it from the Orbit side.
