These 2 weather stations are in Sweden, I’m not in Sweden.
My controller settings show the correct address in Minnesota, USA, but going to “Edit Weather Station” the map loads and zooms across the atlantic to only show ESCM and ESSA weather stations, and 4 more if i turn on PWS.
So, i have to set my schedule on a 6 hour offset because otherwise the schedule functions off the time zone in Sweden.
@vonbargenjl - I’m using the iOS app along with a Gen 3 and it shows nearby weather stations. What flavor of the app is being used? Probably need to submit a support ticket through the app. There was (is?) an intermittent issue with the moisture graph today, so I don’t know if that is connected or not.
chance you can allow schedules to change from ‘fixed’ to one of the other types? instead of having to delete it and make a new one. then it’d be perfection.
