I’ve been using Flex daily scheduling for my entire yard. A few zones look dryer than I’d like. What’s the best way to increase the amount of watering in these zones?
I was thinking of maybe changing Allowed Depletion down. I tried changing from 50% to 30% but it still look dry.
Am I on the right track, but change even lower, or is there an easier way.
If you haven’t run a catch cup test, I’d suggest lowering the rate from the nozzle and returning Allowed Depletion back to the default value as is seems like those zones aren’t getting enough water
I had the same problem. I needed to increase/decrease water on various zones. The single best way I find to do that is by changing the root depth of the zone (I try to make the other settings for the zone accurate - type of plants, soil, sprinkler heads, etc.)
