Best PWS Report Rate?
Is the 5 minute interval referred to at the PWS Setup support article the ideal report rate for Iro? Is every 30 minutes sufficient? (PWSWeather.com seems to encourage that report rate).
The data provider Rachio uses normally provides a daily summary. So 30 minutes update interval should not make a big difference compared to 5 minute updates.
That being said, there will be an extra update one hour prior to running each of your schedules, so 5 minute update interval will have a higher chance of being reported in time to make a difference.
Gene
