I am currently experiencing issues with the Rachio API. As an example, I am no loner seeing rainDelayStartDate and rainDelayExpirationDate in the JSON devices object. I am also no longer seeing the high and low temperatures in the JSON output. Is this a known issue?
Thank you for the fix regarding the high/low temperatures. I also noticed the Zone runtime and maxRuntime are missing. Is that something that can be added back to the API?
Those two fields are not accessible with the new system.
If you really want that data you can derive with this equation using the data retrieved from the zone.
(((x/y)*3600)*((1/(0.4+(0.6*z)))*w))=r
x -> irrigation amount in inches
y -> irrigation flow rate (inches per hour)
z -> efficiency
r -> runtime (minutes)
