The adjustments will mainly be frequency, duration is not really modified. That plus climate skip should get you there. If you want run in parallel, would love concrete feedback regarding the two.
With the old WEB app (https://flex-app.rach.io/) I can add/remove and re-order zones in a schedule. This capability has apparently been removed in the new software, even for fixed schedules. I don’t see how adding/removing, and specially reordering zones would have any effect on the frequency or duration of other zones in the fixed schedule.
Yes, it might change the over all duration of the schedule (undoubtedly if a zone is added or removed!) But the frequency is determined by the fixed watering days.
I ran into this because I wanted to change the order of zone watering so that the zones likely to be watered when the “watering police” are awake were not visible from the street. (they are dinging me for getting 6 inches of the sidewalk wet!) Fortunately the flex web app still allows this.
The way this was handled in the old interface is perfect. Please reinstate it. At least for fixed and flex schedules.
Dude, had the same problem in iOS. @johnny2678 had to set me straight.
In iOS you have to go to the screen that lets you select the zones in the schedule. Press and hold then you can slide them up and down. Glad to know I’m not the only one.
There is no “zones” to click on. I have “Durations” which takes me to the zone list. Once there all that I can do is click the + or - to change the durations. Galaxy S6.
This is a FIXED, not FLEX schedule. FLEX schedules are still using the old code where you can do this. (In the WEB app as well.)
