Hi,
You guys have made a rock solid product. Keep it going!. It’s been over a month and my biggest fear was that Rachio will loose connectivity at sometime with my Airport Extreme, since it is housed outside the home. But no -never. Don’t we all need such solid reliability!?
Ok - Not sure if this has been asked before as I could not find it with a quick scan of all the topics- But my use case is that I need granular control over what the Rachio does- especially given that I have a gradient on the lawn so the station with 4 nozzles at the bottom of the gradient needs much less water than the other station at the top- I can do this and adjust with the heat wave we are having now in AZ. The lawn has never looked better- So my suggestion is this- Rachio has data about the location, temperature, date, time, activity completed and of course settings that were in effect for every station. So next year, same time or maybe a month later, if the Rachio cloud can detect a match with all these variables, then the user should be able to just re-use those settings- this is real intelligence that can be used again and again. Of course you can have a setting that goes from manual to auto-intel or whatever cool term you want to call it. Now imagine how many different ways this analytics can be actioned upon. The more the variables (relevant ones), the more precise is the application and a consistent result. Even if the user is allowed to store this data locally it would be of no use, to manually read and apply etc- it should be from the cloud and applied directly to Rachio
