Zone 16 in the rachio is actually 2 zones wired into it. These 2 zones are for trees only with no grass. Because I’m running them both at the same time the water pressure is half what it would normally be. What’s the easiest way to tell Rachio this so it runs those a little longer on a flex daily schedule?
Try cutting your nozzle inches/hour in half for those two zones. That should bake in run twice as long.
Seems to have done the trick ty!
