1 flow meter 3 controllers
Would like to have 1 flow meter using 3 16 zone controllers. I have 48 zones in my system.
According to the current limits, one can only assign 2 meters per 1 controller. It would be necessary to install 3 WFS to have 1 per controller.
Check this link for the exact explanation.
I hope this helps you.
See my proposed layout.
3 FlowMeters.jpg1400x733 135 KB
We can’t see your photo here. Please try to attach it so we can help with your inquiry. :blush:
Your set up looks good and sound.
In answer to your question about winterizing, you can purchase a blanket that can wrap around them in the colder months. This would help if you are not draining the lines. I would recommend a full system draining to prevent the pipes from bursting at any rate.
Some people install a blow out area so that you can run compressed air on a valve by valve basis. This will help to get 99% of the water out of the lines.
